Ana içeriğe geç
Reverse Applique Patch
Neye ihtiyacın var
  1. Reverse Applique Patch, Reverse Applique Patch: adım 1, 3 resimden 1. Reverse Applique Patch, Reverse Applique Patch: adım 1, 3 resimden 2. Reverse Applique Patch, Reverse Applique Patch: adım 1, 3 resimden 3.
    • Examine the damage. Clip any long threads, and remove any debris from the hole.
    • Measure the damaged area.
    • In our case it looks to be 2" by 2".
    FixBot'a Sor
    Yorum Ekle
  2. Reverse Applique Patch: adım 2, 2 resimden 1. Reverse Applique Patch: adım 2, 2 resimden 2.
    • Draw any the shape you'd like your patch to be on a piece of paper. Be sure your design is at least 1/8" larger than the damaged area.
    • Cut out your design.
    FixBot'a Sor
    Yorum Ekle
  3. Reverse Applique Patch: adım 3, 2 resimden 1. Reverse Applique Patch: adım 3, 2 resimden 2.
    • Lay the cutout of your design over the hole in the jeans to make sure that it is the correct size and looks how you want it to.
    FixBot'a Sor
    Yorum Ekle
  4. Reverse Applique Patch: adım 4, 3 resimden 1. Reverse Applique Patch: adım 4, 3 resimden 2. Reverse Applique Patch: adım 4, 3 resimden 3.
    • Using a pencil, pen, or tailor's chalk, trace the design onto the jeans.
    FixBot'a Sor
    Yorum Ekle
  5. Reverse Applique Patch: adım 5, 3 resimden 1. Reverse Applique Patch: adım 5, 3 resimden 2. Reverse Applique Patch: adım 5, 3 resimden 3.
    • Cut the design out of your jeans.
    • Be sure to only cut one layer of denim, or you will cut through the back of your jeans and need two patches!
    FixBot'a Sor
    Yorum Ekle
  6. Reverse Applique Patch: adım 6, 3 resimden 1. Reverse Applique Patch: adım 6, 3 resimden 2. Reverse Applique Patch: adım 6, 3 resimden 3.
    • Take the scrap of fabric you will use for a patch and insert it into the hole.
    FixBot'a Sor
    Yorum Ekle
  7. Reverse Applique Patch: adım 7, 2 resimden 1. Reverse Applique Patch: adım 7, 2 resimden 2.
    • Slide the pant leg with the patch over the arm of the sewing machine.
    • You may need to remove the sewing machine table for the pant to fit over the sewing machine.
    • If you are still having trouble getting the pant around the arm of the sewing machine, you can rip the side seam of the pant leg to allow room to sew.
    • Be sure that the pant leg is around the arm, and that you are not accidentally sewing the two layers of the pant leg together.
    FixBot'a Sor
    Yorum Ekle
  8. Reverse Applique Patch: adım 8, 2 resimden 1. Reverse Applique Patch: adım 8, 2 resimden 2.
    • Adjust the sewing machine for a zig-zag stitch.
    • Set the stitch length to just under 1/2.
    FixBot'a Sor
    Yorum Ekle
  9. Reverse Applique Patch: adım 9, 2 resimden 1. Reverse Applique Patch: adım 9, 2 resimden 2.
    • Align the edge of the patch with the center of the pressor foot.
    • Be sure that the patch is laying flat.
    • Lower the pressor foot.
    • Begin sewing the zig-zag stitch, following the edge of the hole so that the zig-zag stitch covers the area where the two fabrics meet.
    FixBot'a Sor
    Yorum Ekle
  10. Reverse Applique Patch: adım 10, 3 resimden 1. Reverse Applique Patch: adım 10, 3 resimden 2. Reverse Applique Patch: adım 10, 3 resimden 3.
    • Sew all the way around the patch.
    • Overlap the stitching at the end with the first two or three stitches.
    FixBot'a Sor
    Yorum Ekle
  11. Reverse Applique Patch: adım 11, 2 resimden 1. Reverse Applique Patch: adım 11, 2 resimden 2.
    • Lift the pressor foot and needle.
    • Slide the pant leg off of the arm of the sewing machine.
    • Clip any threads, and admire your work.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
7 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
90.914 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.511 adet Kılavuz yazıldı
2Kılavuz Yorumları
To keep the pattern from entirely fraying or catching on things, it may also help to flip the pants right-side-out and sew again around the pattern edge with the zigzag or a flat stitch.
Alisa - Yanıt Paylaş
worked! i’ve been wearing these torn pants for years. thanks so much!
Meenal Raval - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 71
Son 30 gün: 352
Her zaman: 25,183
