Giriş
These instructions may also help with other Nivona models and with coffee makers from Melitta, Siemens, and Miele—they are all made by the same manufacturer and have a very similar design.
The gaskets and seals of this brewing unit are under much strain and have to be replaced from time to time.
The Nivona brewing unit (brewgroup) is identical with those of other brands, such as Bosch, Siemens or Melitta.
Neye ihtiyacın var
Remove the hose connecting the upper piston and the coffee outlet.
Remove the upper piston.
Remove the Torx T20 screw from the screen of the upper piston.
Take off the cover of the gasket and the gasket.
Replace the gaskets of the upper piston, the coffee outlet and water connector.
Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
Apply all steps in reverse order to re-assemble the device.
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
