Ana içeriğe geç
Revlon 473 Thermal Cutout Replacement
Neye ihtiyacın var
  1. Revlon 473 Thermal Cutout Replacement, Shell: adım 1, 1 resimden 1.
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Thermal Cutout Replacement: adım 2, 1 resimden 1.
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Thermal Cutout Replacement: adım 3, 3 resimden 1. Revlon 473 Thermal Cutout Replacement: adım 3, 3 resimden 2. Revlon 473 Thermal Cutout Replacement: adım 3, 3 resimden 3.
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Thermal Cutout Replacement, Thermal Cutout: adım 4, 1 resimden 1.
    • Locate the thermal cutout under the coils of the heating element.
  5. Revlon 473 Thermal Cutout Replacement: adım 5, 1 resimden 1.
    • Test the thermal cutout for continuity using the multimeter.
    • Make sure the multimeter is set to 200 ACV and bring the probes toward the thermal cutout.
    • If the numbers on the multimeter continue to change, the circuit is closed and properly functioning.
    • If the multimeter reads a consistent number, the circuit is opened and the thermal cutout needs to be replaced.
  6. Revlon 473 Thermal Cutout Replacement: adım 6, 1 resimden 1.
    • To replace the thermal cutout, use the spudgers to extract the object.
    • To remove, wedge it back and forth until it comes free.
    • You do not need to take out the gold piece, only the thermal cutout.
  7. Revlon 473 Thermal Cutout Replacement: adım 7, 1 resimden 1.
    • Replace the old thermal cutout with a new thermal cutout by snapping it into place.
Sonuç
Jessica Leyva
143 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,857
