Ana içeriğe geç
Revlon One-Step Hair Dryer Cord and Plug Replacement
Neye ihtiyacın var
  1. Revlon One-Step Hair Dryer Cord and Plug Replacement, Barrel: adım 1, 1 resimden 1.
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 2, 3 resimden 1. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 2, 3 resimden 2. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 2, 3 resimden 3.
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 3, 3 resimden 1. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 3, 3 resimden 2. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 3, 3 resimden 3.
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
  4. Revlon One-Step Hair Dryer Cord and Plug Replacement, Cord and Plug: adım 4, 2 resimden 1. Revlon One-Step Hair Dryer Cord and Plug Replacement, Cord and Plug: adım 4, 2 resimden 2.
    • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
  5. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 5, 1 resimden 1.
    • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
    • Store screws in a safe place, you will need them to reassemble the device later.
  6. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 6, 1 resimden 1.
    • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
  7. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 7, 3 resimden 1. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 7, 3 resimden 2. Revlon One-Step Hair Dryer Cord and Plug Replacement: adım 7, 3 resimden 3.
    • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
    • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
    • Next with your free hand carefully pull the cord out of the port of the dryer handle.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
buenas noches donde se puede comprar este repuesto (cable ) gracias
JORGE NERI - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 124
Her zaman: 5,487
