Ana içeriğe geç
Rexing V1P Plus Front Camera Replacement
Neye ihtiyacın var
    1. Rexing V1P Plus Front Camera Replacement, Front Camera: adım 1, 3 resimden 1. Rexing V1P Plus Front Camera Replacement, Front Camera: adım 1, 3 resimden 2. Rexing V1P Plus Front Camera Replacement, Front Camera: adım 1, 3 resimden 3.
      • Begin by orienting the device with the LCD screen facing down.
      • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Rexing V1P Plus Front Camera Replacement: adım 2, 3 resimden 1. Rexing V1P Plus Front Camera Replacement: adım 2, 3 resimden 2. Rexing V1P Plus Front Camera Replacement: adım 2, 3 resimden 3.
      • Remove the back cover of the device and place it to the side.
      • Rotate the device 180 degrees to where the camera is facing you.
      FixBot'a Sor
      Yorum Ekle
    3. Rexing V1P Plus Front Camera Replacement: adım 3, 3 resimden 1. Rexing V1P Plus Front Camera Replacement: adım 3, 3 resimden 2. Rexing V1P Plus Front Camera Replacement: adım 3, 3 resimden 3.
      • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Rexing V1P Plus Front Camera Replacement: adım 4, 3 resimden 1. Rexing V1P Plus Front Camera Replacement: adım 4, 3 resimden 2. Rexing V1P Plus Front Camera Replacement: adım 4, 3 resimden 3.
      • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
      FixBot'a Sor
      Yorum Ekle
    5. Rexing V1P Plus Front Camera Replacement: adım 5, 3 resimden 1. Rexing V1P Plus Front Camera Replacement: adım 5, 3 resimden 2. Rexing V1P Plus Front Camera Replacement: adım 5, 3 resimden 3.
      • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Rexing V1P Plus Front Camera Replacement: adım 6, 3 resimden 1. Rexing V1P Plus Front Camera Replacement: adım 6, 3 resimden 2. Rexing V1P Plus Front Camera Replacement: adım 6, 3 resimden 3.
      • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
      • It will rest loosely around the white camera ribbon.
      • Rotate the device 180 degrees to where the camera is facing away from you.
      FixBot'a Sor
      Yorum Ekle
    7. Rexing V1P Plus Front Camera Replacement: adım 7, 3 resimden 1. Rexing V1P Plus Front Camera Replacement: adım 7, 3 resimden 2. Rexing V1P Plus Front Camera Replacement: adım 7, 3 resimden 3.
      • Carefully peel back the adhesive material covering the ribbon cable connection.
      FixBot'a Sor
      Yorum Ekle
    8. Rexing V1P Plus Front Camera Replacement: adım 8, 3 resimden 1. Rexing V1P Plus Front Camera Replacement: adım 8, 3 resimden 2. Rexing V1P Plus Front Camera Replacement: adım 8, 3 resimden 3.
      • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
      • Once the connector is open, slide the ribbon cable out to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 383
