Ana içeriğe geç
Ricoh Shotmaster 130Z Shutter LED Replacement
Neye ihtiyacın var
  1. Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: adım 1, 3 resimden 1. Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: adım 1, 3 resimden 2. Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: adım 1, 3 resimden 3.
    • Using a Phillips J00 head remove the three 5mm screws on both left and right side of the camera as well as the one in back of it.
    FixBot'a Sor
    Yorum Ekle
  2. Ricoh Shotmaster 130Z Shutter LED  Replacement: adım 2, 1 resimden 1.
    • Using the same J00 phillips head screwdriver proceed to removing the remaining four 5mm screws on the bottom of the camera.
    • Last, using the same #00 phillips head screwdriver remove the two 0.6mm screws which are one on each side of the tripod connection dip.
    FixBot'a Sor
    Yorum Ekle
  3. Ricoh Shotmaster 130Z Shutter LED  Replacement: adım 3, 2 resimden 1. Ricoh Shotmaster 130Z Shutter LED  Replacement: adım 3, 2 resimden 2.
    • The case can now be removed from the camera.
    • Using a blue opening tool start by lifting the back part of the case right where the tripod dip is. Lift until the back part of the case is released and can be easily removed
    • Next, using the same opening tool lift and push by the battery compartment as shown in the second picture. Do this until the front part of the case is released and can be easily removed.
    FixBot'a Sor
    Yorum Ekle
  4. Ricoh Shotmaster 130Z Shutter LED  Replacement: adım 4, 2 resimden 1. Ricoh Shotmaster 130Z Shutter LED  Replacement: adım 4, 2 resimden 2.
    • The LED diode to be replaced can be found in the front of the camera next to the zooming lens.
    • Desolder the LED to remove it from the motherboard
    FixBot'a Sor
    Yorum Ekle
Sonuç
anna carolina von einem
450 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 UMass Dartmouth, Team 3-4, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 530
