Ana içeriğe geç
Ricoh Shotmaster 130Z Zooming Lens Replacement
Neye ihtiyacın var
  1. Ricoh Shotmaster 130Z Zooming Lens Replacement, Zooming Lens: adım 1, 1 resimden 1.
    • Set the dials to "A" (Auto), and Off mode.
    • You will not be able to move these dials once the case has been opened.
  2. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 2, 3 resimden 1. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 2, 3 resimden 2. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 2, 3 resimden 3.
    • Remove the 5 Phillips screws from the sides and the back.
  3. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 3, 2 resimden 1. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 3, 2 resimden 2.
    • Remove the 5mm JIS #00 screws from the bottom of the camera.
    • Pay attention to the 6mm screws on the sides of the tripod slot, as they are a slightly different size from the rest of the screws. However, you still may use a J00 screwdriver to remove them.
  4. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 4, 2 resimden 1. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 4, 2 resimden 2.
    • Using an opening tool, lift the case of the tripod slot (on the bottom) until the back portion of the case is released.
    • Continue to use the the opening tool to insert it and lift right next to the strap of the camera.
    • This will release the front portion of the case.
  5. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 5, 3 resimden 1. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 5, 3 resimden 2. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 5, 3 resimden 3.
    • Use a JIS #0 screwdriver to remove the three marked screws found around the perimeter of the lens.
  6. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 6, 3 resimden 1. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 6, 3 resimden 2. Ricoh Shotmaster 130Z Zooming Lens Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Proceed to remove the two screws using a JIS #00 screwdriver.
    • Use tweezers to lift the lens off of the board.
Sonuç
anna carolina von einem
450 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 UMass Dartmouth, Team 3-4, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 552
