Ana içeriğe geç
Ricoh Theta S Battery Replacement
Neye ihtiyacın var
  1. Ricoh Theta S Battery Replacement, Outer Case: adım 1, 1 resimden 1.
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Battery Replacement: adım 2, 2 resimden 1. Ricoh Theta S Battery Replacement: adım 2, 2 resimden 2.
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Battery Replacement: adım 3, 3 resimden 1. Ricoh Theta S Battery Replacement: adım 3, 3 resimden 2. Ricoh Theta S Battery Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
  4. Ricoh Theta S Battery Replacement, Battery: adım 4, 2 resimden 1. Ricoh Theta S Battery Replacement, Battery: adım 4, 2 resimden 2.
    • The battery is located near the bottom of the device.
    • Flip the plastic containing thermal compound over so it is resting on top of the battery.
  5. Ricoh Theta S Battery Replacement: adım 5, 2 resimden 1. Ricoh Theta S Battery Replacement: adım 5, 2 resimden 2.
    • Lift the battery out of the device, beginning with the end closest to the camera.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Bradley Sutton
737 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G1
3 Üyeler
8 Yorum
Nice demonstration, but if I can’t find a DB-110 replacement battery, I’m not sure if I would take the camera apart. If I find a replacement, this step-by-step demonstration will be very helpful.
Joel Brondos - Yanıt
The battery replacement for Ricoh Theta S is the Olympus battery model LI-92B.
It’s the perfect equivalent of the original Ricoh DB-110 battery. Tested personally.
Please don’t use any other similar battery or you risk to breaking the charge control circuit of the camera!!
Please note that you nullify the warranty, if the item is under coverage.
Franco - Yanıt
Do you have a good link for Olympus battery model LI-92B ?
Patrick D - Yanıt
It its very important to observe to remove the right side of the camera cover ! it is the side without button !!!
wkaemena - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 82
Her zaman: 10,036
