Ana içeriğe geç
Ricoh Theta S Outer Case Replacement
Neye ihtiyacın var
  1. Ricoh Theta S Outer Case Replacement, Outer Case: adım 1, 1 resimden 1.
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: adım 2, 2 resimden 1. Ricoh Theta S Outer Case Replacement: adım 2, 2 resimden 2.
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Outer Case Replacement: adım 3, 3 resimden 1. Ricoh Theta S Outer Case Replacement: adım 3, 3 resimden 2. Ricoh Theta S Outer Case Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
Sonuç
Bradley Sutton
737 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G1
3 Üyeler
Bir Yorum
Where can find spare part case?
Thanks
Franco - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 2,179
