Giriş
I created this guide because I found nothing in the internet about changing this battery.
Neye ihtiyacın var
Use a Spudger to remove the sticker, starting from the reset hole.
The using 00-Torx remove the 3 screws at the bottom.
Now remove the screw at the side with the 00-Torx screwdriver.
Gently remove the side pieces.
Now one part of the case can be pulled away, carefully observing the pin for the strap holder.
The battery is glued with tape to a holder, that has to be unscrewed.
6 Yorum
Great guide, thanks. May i know the battery detail that you use for the replacement.
👍 This was so helpful and easy to do ! Thank you 😀 * Bought DB 110 (same as for Ricoh Theta X) on Amazon for 49 €
Thank you for your post. I just called Ricoh for assistance and was referred to www.precisioncamera.com/ricoh, where I was quoted $833 to replace the battery.
I have just ordered a replacement battery on Amazon and will be doing it myself. Ricoh and PrecisionCamera can go FYT!
