Ana içeriğe geç
Giriş
This process involves removing the back cover, front cover, and various other camera components. After, the button mechanism can be removed.
Parçalar
Hiçbir parça belirtilmedi.
  1. Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera. Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera.
    • Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera.
  2. Loosen the back cover from both the left and the right sides of the camera. Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything. Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything.
    • Loosen the back cover from both the left and the right sides of the camera.
    • Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything.
  3. Open the film compartment. Press your finger on top of the grey latch on the left side of the camera. Press your finger on top of the grey latch on the left side of the camera.
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Removing the film compartment door is optional. However, it may aid maneuverability in future steps. Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place. Use your fingers to completely remove the metal pin.
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  6. Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment. Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment.
    • Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment.
  7. Loosen the front cover from the left and right sides of the camera. Remove the front cover. Remove the front cover.
    • Loosen the front cover from the left and right sides of the camera.
    • Remove the front cover.
  8. The button mechanism is only attached to the camera body itself. Set the front and back covers aside. Remove the one screw that holds the front face plate brace in place. Remove brace.
    • The button mechanism is only attached to the camera body itself. Set the front and back covers aside.
    • Remove the one screw that holds the front face plate brace in place.
    • Remove brace.
  9. Unscrew the four screws keeping the front face plate in place. The top left screw also holds a metal clip in place. Remove metal clip.
    • Unscrew the four screws keeping the front face plate in place.
    • The top left screw also holds a metal clip in place.
    • Remove metal clip.
  10. After removing the metal clip in the previous step, the front face plate can be removed. The front face plate is attached to the camera body by two small wires. Remove the plate carefully and do completely separate from camera body. The front face plate is attached to the camera body by two small wires. Remove the plate carefully and do completely separate from camera body.
    • After removing the metal clip in the previous step, the front face plate can be removed.
    • The front face plate is attached to the camera body by two small wires. Remove the plate carefully and do completely separate from camera body.
  11. Unscrew the two screws that hold the button mechanism in place. Press down on button mechanism to unlatch it from the camera body. When pressed down, the bottom of the mechanism should push outward. Press down on button mechanism to unlatch it from the camera body. When pressed down, the bottom of the mechanism should push outward.
    • Unscrew the two screws that hold the button mechanism in place.
    • Press down on button mechanism to unlatch it from the camera body. When pressed down, the bottom of the mechanism should push outward.
  12. Lift the button mechanism up carefully, removing the spring at the top of the mechanism from where it is attached to the camera body. Remove the button mechanism. Remove the button mechanism.
    • Lift the button mechanism up carefully, removing the spring at the top of the mechanism from where it is attached to the camera body.
    • Remove the button mechanism.
Sonuç
Eric Dazet
352 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-21, Amido Spring 2012 Cal Poly, Team 6-21, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S6G21
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 10
Her zaman: 554
