Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
Open the film compartment.
Press your finger on top of the grey latch on the left side of the camera.
Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
Use your fingers to completely remove the metal pin.
Remove the film compartment door.
Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
Loosen the front cover from the left and right sides of the camera.
Take off the front cover.
Bir başkası bu kılavuzu tamamladı.
