Ana içeriğe geç
Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement
Neye ihtiyacın var
  1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: adım 1, 3 resimden 1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: adım 1, 3 resimden 2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: adım 1, 3 resimden 3.
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: adım 2, 3 resimden 1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: adım 2, 3 resimden 2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: adım 2, 3 resimden 3.
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: adım 3, 3 resimden 1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: adım 3, 3 resimden 2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: adım 3, 3 resimden 3.
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: adım 4, 2 resimden 1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: adım 4, 2 resimden 2.
    • The motor housing assembly can now be removed from the rest of the saw.
Sonuç
Joshua Caron
792 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G2, Julie Spring 2019 UMass Dartmouth, Team S5-G2, Julie Spring 2019 üyesi
UMASSD-JULIE-S19S5G2
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 384
