Ana içeriğe geç
Ridgid Circular Saw R3205 Spindle Lock Replacement
Neye ihtiyacın var
  1. Ridgid Circular Saw R3205 Spindle Lock Replacement, Blade: adım 1, 2 resimden 1. Ridgid Circular Saw R3205 Spindle Lock Replacement, Blade: adım 1, 2 resimden 2.
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 2, 1 resimden 1.
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 3, 3 resimden 1. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 3, 3 resimden 2. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 3, 3 resimden 3.
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Spindle Lock Replacement, Lower Blade Guard: adım 4, 2 resimden 1. Ridgid Circular Saw R3205 Spindle Lock Replacement, Lower Blade Guard: adım 4, 2 resimden 2.
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 5, 3 resimden 1. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 5, 3 resimden 2. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 5, 3 resimden 3.
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 6, 1 resimden 1.
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 7, 2 resimden 1. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 7, 2 resimden 2.
    • Remove the lower blade guard after removing the washer.
  8. Ridgid Circular Saw R3205 Spindle Lock Replacement, Spindle Lock: adım 8, 1 resimden 1.
    • Remove the (M3 x 12 mm) screw using a phillips head screwdriver.
  9. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 9, 1 resimden 1.
    • Leave the rubber dust cover below the removed screw.
  10. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 10, 3 resimden 1. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 10, 3 resimden 2. Ridgid Circular Saw R3205 Spindle Lock Replacement: adım 10, 3 resimden 3.
    • Pull out the Spindle Lock.
Sonuç
Joshua Caron
792 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G2, Julie Spring 2019 UMass Dartmouth, Team S5-G2, Julie Spring 2019 üyesi
UMASSD-JULIE-S19S5G2
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,525
