Ana içeriğe geç
Ridgid Circular Saw R3205 Switch Replacement
Neye ihtiyacın var
  1. Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: adım 1, 3 resimden 1. Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: adım 1, 3 resimden 2. Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: adım 1, 3 resimden 3.
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Switch Replacement: adım 2, 3 resimden 1. Ridgid Circular Saw R3205 Switch Replacement: adım 2, 3 resimden 2. Ridgid Circular Saw R3205 Switch Replacement: adım 2, 3 resimden 3.
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Switch Replacement: adım 3, 3 resimden 1. Ridgid Circular Saw R3205 Switch Replacement: adım 3, 3 resimden 2. Ridgid Circular Saw R3205 Switch Replacement: adım 3, 3 resimden 3.
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Switch Replacement: adım 4, 2 resimden 1. Ridgid Circular Saw R3205 Switch Replacement: adım 4, 2 resimden 2.
    • The motor housing assembly can now be removed from the rest of the saw.
  5. Ridgid Circular Saw R3205 Switch Replacement, Switch: adım 5, 1 resimden 1.
    • Remove 5 Torx 20 (#8-16 x 5/8 in.) screws from the outer handle.
  6. Ridgid Circular Saw R3205 Switch Replacement: adım 6, 3 resimden 1. Ridgid Circular Saw R3205 Switch Replacement: adım 6, 3 resimden 2. Ridgid Circular Saw R3205 Switch Replacement: adım 6, 3 resimden 3.
    • Remove the outer handle.
  7. Ridgid Circular Saw R3205 Switch Replacement: adım 7, 1 resimden 1.
    • Using a phillips head screwdriver remove the (M4 x 12 mm) screw holding the switch in place.
  8. Ridgid Circular Saw R3205 Switch Replacement: adım 8, 3 resimden 1. Ridgid Circular Saw R3205 Switch Replacement: adım 8, 3 resimden 2. Ridgid Circular Saw R3205 Switch Replacement: adım 8, 3 resimden 3.
    • Remove the wires that attach to the power cord.
Sonuç
Joshua Caron
792 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G2, Julie Spring 2019 UMass Dartmouth, Team S5-G2, Julie Spring 2019 üyesi
UMASSD-JULIE-S19S5G2
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 770
