Ana içeriğe geç
Ridgid GEN5X R8611506 Speed Selector Switch Replacement
Neye ihtiyacın var
  1. Ridgid GEN5X R8611506 Speed Selector Switch Replacement, Outer Case: adım 1, 2 resimden 1. Ridgid GEN5X R8611506 Speed Selector Switch Replacement, Outer Case: adım 1, 2 resimden 2.
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Speed Selector Switch Replacement: adım 2, 3 resimden 1. Ridgid GEN5X R8611506 Speed Selector Switch Replacement: adım 2, 3 resimden 2. Ridgid GEN5X R8611506 Speed Selector Switch Replacement: adım 2, 3 resimden 3.
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Speed Selector Switch Replacement: adım 3, 2 resimden 1. Ridgid GEN5X R8611506 Speed Selector Switch Replacement: adım 3, 2 resimden 2.
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Speed Selector Switch Replacement: adım 4, 2 resimden 1. Ridgid GEN5X R8611506 Speed Selector Switch Replacement: adım 4, 2 resimden 2.
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
  5. Ridgid GEN5X R8611506 Speed Selector Switch Replacement, Speed Selector Switch: adım 5, 1 resimden 1.
    • Locate the selector switch.
    • Unhook the selector switch from the small silver wire located near the top of the drill.
  6. Ridgid GEN5X R8611506 Speed Selector Switch Replacement: adım 6, 1 resimden 1.
    • Remove the speed selector switch from the case housing.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 424
