Ana içeriğe geç
Ridgid GEN5X R8653 Base Assembly Replacement
Neye ihtiyacın var
  1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: adım 1, 3 resimden 1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: adım 1, 3 resimden 2. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: adım 1, 3 resimden 3.
    • Always disconnect battery and use gloves when working with the saw blade. Failure to do so may result in damage or injury!
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
  2. Ridgid GEN5X R8653 Base Assembly Replacement: adım 2, 3 resimden 1. Ridgid GEN5X R8653 Base Assembly Replacement: adım 2, 3 resimden 2. Ridgid GEN5X R8653 Base Assembly Replacement: adım 2, 3 resimden 3.
    • Remove seven 6mm T20 Torx screws located around base of saw.
    • Pull base assembly away from saw.
    • These screws are very tight and need significant force to be removed.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 219
