Ana içeriğe geç
Ridgid JobMax R2851 Series B Directional Button Replacement
Neye ihtiyacın var
  1. Ridgid JobMax R2851 Series B Directional Button Replacement, Directional Button: adım 1, 2 resimden 1. Ridgid JobMax R2851 Series B Directional Button Replacement, Directional Button: adım 1, 2 resimden 2.
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 2, 1 resimden 1.
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 3, 1 resimden 1.
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 4, 2 resimden 1. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 4, 2 resimden 2.
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 5, 3 resimden 1. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 5, 3 resimden 2. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 5, 3 resimden 3.
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 6, 1 resimden 1.
    • Grab the trigger mechanism, and lift it up and away from the device.
    • Be gentle when lifting it out—it is still attached by short wires.
  7. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 7, 2 resimden 1. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 7, 2 resimden 2.
    • Slide and wiggle the metal rod holding down the directional button.
    • This rod is connected by two small holes in the directional button so moving up and to the right is the best.
  8. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 8, 2 resimden 1. Ridgid JobMax R2851 Series B Directional Button Replacement: adım 8, 2 resimden 2.
    • Slide the directional button up and out of the device.
    • Hole and slot for reassembly
    • After the button is replaced, the metal rod fits into a small hole and slot to the right of the button. The tiny spring has to be slid over to set it in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 634
