Ana içeriğe geç
Ridgid JobMax R2851 Series B Motor Brushes Replacement
Neye ihtiyacın var
  1. Ridgid JobMax R2851 Series B Motor Brushes Replacement, Motor: adım 1, 2 resimden 1. Ridgid JobMax R2851 Series B Motor Brushes Replacement, Motor: adım 1, 2 resimden 2.
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 2, 1 resimden 1.
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 3, 1 resimden 1.
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 4, 2 resimden 1. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 4, 2 resimden 2.
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 5, 3 resimden 1. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 5, 3 resimden 2. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 5, 3 resimden 3.
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 6, 2 resimden 1. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 6, 2 resimden 2.
    • Grip each of the sides of the two green circuit boards and slide them up.
    • Grip each side of the device trigger, and slide it up.
    • You do not need to completely remove these parts. Sliding them upward provides the needed room.
  7. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 7, 2 resimden 1. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 7, 2 resimden 2.
    • Grip the motor firmly and pull towards the back of the tool, rotating back forth until the motor is free.
    • When reinstalling the motor, use a spudger to pull back the brushes. This allows the motor to slide into place.
  8. Ridgid JobMax R2851 Series B Motor Brushes Replacement, Motor Brushes: adım 8, 3 resimden 1. Ridgid JobMax R2851 Series B Motor Brushes Replacement, Motor Brushes: adım 8, 3 resimden 2. Ridgid JobMax R2851 Series B Motor Brushes Replacement, Motor Brushes: adım 8, 3 resimden 3.
    • Pinch the brush and pry upward away from the center of the part to remove from the device.
    • Take care to not damage the connections on the bottom of the brush.
  9. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 9, 2 resimden 1. Ridgid JobMax R2851 Series B Motor Brushes Replacement: adım 9, 2 resimden 2.
    • Firmly hold the brush in one hand and pull at the base of the wire to disconnect.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Anyone know where I can buy replacement burshes? Great write up! Thanks
Bradley Pelz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 950
