Ana içeriğe geç
Ridgid JobMax R8620 Series E Drive Gear Cover Replacement
Neye ihtiyacın var
  1. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement, Drive Gear Cover: adım 1, 1 resimden 1.
    • Pull the battery out of the case by hand before opening the device.
    • Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
    • Lift off the outer casing.
  2. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: adım 2, 1 resimden 1.
    • After opening the cover, find the motor and pry it apart from the case in order to have space to do the replacement.
  3. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: adım 3, 3 resimden 1. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: adım 3, 3 resimden 2. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: adım 3, 3 resimden 3.
    • Find the gear cover.
    • Using a Phillips #0 screwdriver, remove the two screws on the plastic protective plate.
    • Remove the plastic plate.
  4. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: adım 4, 2 resimden 1. Ridgid JobMax R8620 Series E Drive Gear Cover Replacement: adım 4, 2 resimden 2.
    • Carefully pull off the gear cover.
Sonuç
Pengjian Zhou
533 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S20-G1, Lore Winter 2019 UC Davis, Team S20-G1, Lore Winter 2019 üyesi
UCD-LORE-W19S20G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 711
