Ana içeriğe geç
Ridgid JobMax R8620 Series E LED Grip Light Replacement
Neye ihtiyacın var
  1. Ridgid JobMax R8620 Series E LED Grip Light Replacement, LED Light: adım 1, 1 resimden 1.
    • Pull the battery out of the case by hand before opening the device.
    • Using a Torx T10 screwdriver, remove the nine 6mm screws on the drill cover.
    • Lift off the outer casing.
  2. Ridgid JobMax R8620 Series E LED Grip Light Replacement: adım 2, 2 resimden 1. Ridgid JobMax R8620 Series E LED Grip Light Replacement: adım 2, 2 resimden 2.
    • Using a spudger or your fingers, remove the LED light from the groove in the handle.
  3. Ridgid JobMax R8620 Series E LED Grip Light Replacement: adım 3, 2 resimden 1. Ridgid JobMax R8620 Series E LED Grip Light Replacement: adım 3, 2 resimden 2.
    • Carefully remove the motor as well as the main board from the drill cover.
  4. Ridgid JobMax R8620 Series E LED Grip Light Replacement: adım 4, 2 resimden 1. Ridgid JobMax R8620 Series E LED Grip Light Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Find the corresponding position of the LED line on the motherboard. If necessary, use tweezers to pull it out and replace it.
Sonuç
Pengjian Zhou
557 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S20-G1, Lore Winter 2019 UC Davis, Team S20-G1, Lore Winter 2019 üyesi
UCD-LORE-W19S20G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 209
