Ana içeriğe geç
Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement
Neye ihtiyacın var
  1. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement, LED Grip Light Switch: adım 1, 1 resimden 1.
    • Pull the battery out of the case before opening the device.
    • Remove the nine 6mm screws on the drill cover using a Torx T10 screwdriver.
    • Lift off the outer casing.
  2. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: adım 2, 1 resimden 1.
    • Locate the LED grip light switch at the waist of the device.
  3. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: adım 3, 2 resimden 1. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: adım 3, 2 resimden 2.
    • Remove the plastic switch with the spring from the groove of the housing by hand.
    • Check to see if there are problems with the plastic switch or the spring.
  4. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: adım 4, 2 resimden 1. Ridgid JobMax R8620 Series E LED Grip Light Switch Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Find the slot on the motherboard along the wiring of the device.
    • Use tweezers to pull the plug out of the host slot.
Sonuç
Pengjian Zhou
557 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S20-G1, Lore Winter 2019 UC Davis, Team S20-G1, Lore Winter 2019 üyesi
UCD-LORE-W19S20G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 469
