Ana içeriğe geç
Ridgid R2601 Power Cord Replacement
Neye ihtiyacın var
    1. Ridgid R2601 Power Cord  Replacement, Top Cover: adım 1, 1 resimden 1.
      • Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Ridgid R2601 Power Cord  Replacement: adım 2, 1 resimden 1.
      • Pull off the top cover.
      FixBot'a Sor
      Yorum Ekle
    1. Ridgid R2601 Power Cord  Replacement, Power Cord: adım 3, 2 resimden 1. Ridgid R2601 Power Cord  Replacement, Power Cord: adım 3, 2 resimden 2.
      • Remove the two #6-19 x 15mm screws on the black retaining bracket using a Torx T15 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Ridgid R2601 Power Cord  Replacement: adım 4, 1 resimden 1.
      • Pop out and remove the black retaining bracket with your fingers.
      FixBot'a Sor
      Yorum Ekle
    3. Ridgid R2601 Power Cord  Replacement: adım 5, 2 resimden 1. Ridgid R2601 Power Cord  Replacement: adım 5, 2 resimden 2.
      • Loosen the screws in the white terminal block with a small flathead screwdriver. Note that you do not need to fully unscrew and remove them.
      FixBot'a Sor
      Yorum Ekle
    4. Ridgid R2601 Power Cord  Replacement: adım 6, 1 resimden 1.
      • Pull the wiring out from the white cover. The power cord can now be replaced by completing these steps in reverse.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ellie Lott
461 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S20-G3, Lore Winter 2019 UC Davis, Team S20-G3, Lore Winter 2019 üyesi
UCD-LORE-W19S20G3
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 919
