Ana içeriğe geç
Ridgid R2611 Switch Bracket Replacement
Neye ihtiyacın var
  1. Ridgid R2611 Switch Bracket Replacement, Switch Bracket: adım 1, 1 resimden 1.
    • Remove the seven 2.5 mm screws on the top of the sander using the Torx T15 screwdriver.
  2. Ridgid R2611 Switch Bracket Replacement: adım 2, 1 resimden 1.
    • Remove the top of the sander and put to the side.
  3. Ridgid R2611 Switch Bracket Replacement: adım 3, 1 resimden 1.
    • Use the screwdriver to unscrew the two #6-19 X 5/8 in screws holding down the outlet cord.
  4. Ridgid R2611 Switch Bracket Replacement: adım 4, 1 resimden 1.
    • Remove the cord from the handle.
  5. Ridgid R2611 Switch Bracket Replacement: adım 5, 1 resimden 1.
    • Remove the outer plastic piece holding down the white and black wires.
  6. Ridgid R2611 Switch Bracket Replacement: adım 6, 1 resimden 1.
    • Unplug the two connecting pieces that hold wires.
  7. Ridgid R2611 Switch Bracket Replacement: adım 7, 1 resimden 1.
    • Using the screwdrivers, unscrew the four #6-19 X 5/8 in screws on rectangular block.
  8. Ridgid R2611 Switch Bracket Replacement: adım 8, 1 resimden 1.
    • Remove the black and white wires by pulling out.
  9. Ridgid R2611 Switch Bracket Replacement: adım 9, 1 resimden 1.
    • Put the screwdriver in the holes to release remaining two wires.
  10. Ridgid R2611 Switch Bracket Replacement: adım 10, 1 resimden 1.
    • Remove the two remaining wires from switch, leaving the switch freed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ana
384 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 281
