Ana içeriğe geç
Ridgid R82005 Housing Assembly Replacement
Neye ihtiyacın var
  1. Ridgid R82005 Housing Assembly  Replacement, Housing Assembly: adım 1, 1 resimden 1.
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005 Housing Assembly  Replacement: adım 2, 1 resimden 1.
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Housing Assembly  Replacement: adım 3, 2 resimden 1. Ridgid R82005 Housing Assembly  Replacement: adım 3, 2 resimden 2.
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005 Housing Assembly  Replacement: adım 4, 2 resimden 1. Ridgid R82005 Housing Assembly  Replacement: adım 4, 2 resimden 2.
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
Sonuç
To reassemble your device, follow these instructions in reverse order. Also reinsert the battery to make sure the drill has power.
2 farklı kişi bu kılavuzu tamamladı.
Alex Cominos
376 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 296
