Ana içeriğe geç
Ridgid R86008 Gearbox Replacement
Neye ihtiyacın var
  1. Ridgid R86008 Gearbox Replacement, Gearbox: adım 1, 1 resimden 1.
    • Before you begin make sure battery is removed from drill.
    • Loosen the four 13mm T10 Torx screws from the back of the drill and remove cap.
  2. Ridgid R86008 Gearbox Replacement: adım 2, 1 resimden 1.
    • Remove the two 25mm T10 Torx screws from the front of the drill.
  3. Ridgid R86008 Gearbox Replacement: adım 3, 1 resimden 1.
    • Remove the remaining 13mm T10 Torx screws and pull apart drill case.
  4. Ridgid R86008 Gearbox Replacement: adım 4, 1 resimden 1.
    • Identify gearbox.
  5. Ridgid R86008 Gearbox Replacement: adım 5, 3 resimden 1. Ridgid R86008 Gearbox Replacement: adım 5, 3 resimden 2. Ridgid R86008 Gearbox Replacement: adım 5, 3 resimden 3.
    • Using a PH1 screwdriver, remove the four 13mm PH screws from the back of the gearbox.
    • It may be easier to unscrew the screws by separating the front end of the drill from the rest of the drill.
  6. Ridgid R86008 Gearbox Replacement: adım 6, 1 resimden 1.
    • Pull apart gearbox.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 655
