Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Ridgid R86034 Direction Switch Replacement
Neye ihtiyacın var
  1. Ridgid R86034 Direction Switch Replacement, Disassembling Ridgid R86034 Housing: adım 1, 1 resimden 1.
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use some force; the rubber cover is securely attached to the housing.
    • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
    • Orientation is important when putting the rubber cover on the casing.
  2. Ridgid R86034 Direction Switch Replacement: adım 2, 2 resimden 1. Ridgid R86034 Direction Switch Replacement: adım 2, 2 resimden 2.
    • Remove the plastic cover with your hands.
    • There is no need to force off the plastic cover. The plastic cover should be much easier to remove than the rubber cover.
  3. Ridgid R86034 Direction Switch Replacement: adım 3, 3 resimden 1. Ridgid R86034 Direction Switch Replacement: adım 3, 3 resimden 2. Ridgid R86034 Direction Switch Replacement: adım 3, 3 resimden 3.
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
  4. Ridgid R86034 Direction Switch Replacement: adım 4, 2 resimden 1. Ridgid R86034 Direction Switch Replacement: adım 4, 2 resimden 2.
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
  5. Ridgid R86034 Direction Switch Replacement: adım 5, 1 resimden 1.
    • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger.
    • The housing is easier to remove if you pry from multiple sides.
  6. Ridgid R86034 Direction Switch Replacement: adım 6, 2 resimden 1. Ridgid R86034 Direction Switch Replacement: adım 6, 2 resimden 2.
    • Do not remove the direction switch.
    • Pull out all electrical components from housing by hand.
    • Lift out the motor.
    • Follow the wires.
    • The components should come out of their respective slots with ease and require little force to lift out.
    • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
  7. Ridgid R86034 Direction Switch Replacement, Direction Switch: adım 7, 1 resimden 1.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sean Liston
311 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-5, Amido Spring 2015 Cal Poly, Team 15-5, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G5
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,511
