Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The trigger is a multi-speed switch and requires replacing the whole assembly. Soldering is necessary for this guide. Please familiarize yourself with the iFixit guide on Soldering before starting.
  1. Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use some force; the rubber cover is securely attached to the housing.
    • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
    • Orientation is important when putting the rubber cover on the casing.
  2. Remove the plastic cover with your hands. There is no need to force off the plastic cover. The plastic cover should be much easier to remove than the rubber cover.
    • Remove the plastic cover with your hands.
    • There is no need to force off the plastic cover. The plastic cover should be much easier to remove than the rubber cover.
  3. Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver. Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove. Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
  4. Unscrew the eight 15 mm T10 Torx screws from the housing The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
  5. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  6. Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger.
    • The housing is easier to remove if you pry from multiple sides.
  7. Do not remove the direction switch. Pull out all electrical components from housing by hand.
    • Do not remove the direction switch.
    • Pull out all electrical components from housing by hand.
    • Lift out the motor.
    • Follow the wires.
    • The components should come out of their respective slots with ease and require little force to lift out.
    • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
  8. Identify the LED light. Look for the component with clear casing with two wires attached located toward the bottom of the driver.
    • Identify the LED light. Look for the component with clear casing with two wires attached located toward the bottom of the driver.
  9. Cut the pink and white wire attached to the LED as a little more than a quarter inch from the LED. Cut the pink and white wire attached to the LED as a little more than a quarter inch from the LED. Cut the pink and white wire attached to the LED as a little more than a quarter inch from the LED.
    • Cut the pink and white wire attached to the LED as a little more than a quarter inch from the LED.
  10. Strip the wires on the LED by a quarter inch.
    • Strip the wires on the LED by a quarter inch.
  11. Strip the wires that were connected to the LED on the circuit board about a quarter inch. Strip the wires that were connected to the LED on the circuit board about a quarter inch.
    • Strip the wires that were connected to the LED on the circuit board about a quarter inch.
  12. Solder the new LED with striped wires to the wire attached to the circuit board.
    • Solder the new LED with striped wires to the wire attached to the circuit board.
    • Wrap the newly soldered connection with electrical tape to ensure that the circuit isn't shorted.
Sonuç
Sean Liston
275 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 15-5, Amido Spring 2015 Cal Poly, Team 15-5, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G5
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 581
