Giriş
If the sound on your Rienok S1 Mini is muffled or the grille is dirty, use this guide to replace the grille. Additionally any repairs or replacements on the internals of the speaker will require taking the grille off.
The grille of the speaker is meant to protect the internals from any outside objects that would cause damage; If dented or ripped, this protection is reduced. The grille is also meant to allow the sound to pass through. If it gets clogged, the sound will be impeded by these obstructions.
Before beginning, ensure the device is powered off and all cords are unplugged.
Neye ihtiyacın var
Start with the buttons panel up and facing you.
Wedge in one iFixit opening pick, and apply outward pressure to pop out one side of the grille.
Using a second pick, slide from the first pick towards the opposite end until one whole side is popped out.
