Giriş
Follow this guide to replace the camera module for the Ring Floodlight Cam. The camera module plays a critical part in the Ring Floodlight Cam, providing high-definition 4k or 1080p surveillance video footage, recording based on motion activation, and audio in real time.
Disclaimer - This guide involves the drilling of the device shell, which can lead to exposure of various weathering implications if said drill holes are not repaired before use again. As a recommendation, outside resources/products such as weathering tape (ex: Gorilla All Weather Tape) or waterproof sealant putty (ex: Flex Paste) can be used to seal the damage.
Warning - If attempting to remove screws without drilling use a low profile wrench instead of a screwdriver and unless other attempts to remove screws non-destructively have failed follow the guide as originally instructed.
Neye ihtiyacın var
To reassemble your device, follow these instructions in reverse order and before inserting power supply fill the drill holes with plastic putty.
