Ana içeriğe geç
Ring Outdoor Security Cam Battery Replacement
Neye ihtiyacın var
  1. Ring Outdoor Security Cam Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
  2. Ring Outdoor Security Cam Battery Replacement: adım 2, 1 resimden 1.
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Outdoor Security Cam Battery Replacement: adım 3, 1 resimden 1.
    • Using the same tool pry the back plate off of the device.
  4. Ring Outdoor Security Cam Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery power leads using a plastic opening tool.
  5. Ring Outdoor Security Cam Battery Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
Sonuç
WilliamB22
941 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 200
