Ana içeriğe geç
Ring Outdoor Security Cam Microphone Replacement
Neye ihtiyacın var
  1. Ring Outdoor Security Cam Microphone Replacement, Microphone: adım 1, 1 resimden 1.
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
    FixBot'a Sor
    Yorum Ekle
  2. Ring Outdoor Security Cam Microphone Replacement: adım 2, 1 resimden 1.
    • Pry off the aluminum plate using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. Ring Outdoor Security Cam Microphone Replacement: adım 3, 1 resimden 1.
    • Use an opening tool to pry the back plate off of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Ring Outdoor Security Cam Microphone Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery power leads using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  5. Ring Outdoor Security Cam Microphone Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    FixBot'a Sor
    Yorum Ekle
  6. Ring Outdoor Security Cam Microphone Replacement: adım 6, 1 resimden 1.
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the 3 silver 6 mm Phillips #00 screws from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Ring Outdoor Security Cam Microphone Replacement: adım 7, 1 resimden 1.
    • Pull the top of the motherboard up and out of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Ring Outdoor Security Cam Microphone Replacement: adım 8, 2 resimden 1. Ring Outdoor Security Cam Microphone Replacement: adım 8, 2 resimden 2.
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Remove the 3 plastic spacers on the device.
    FixBot'a Sor
    Yorum Ekle
  9. Ring Outdoor Security Cam Microphone Replacement: adım 9, 3 resimden 1. Ring Outdoor Security Cam Microphone Replacement: adım 9, 3 resimden 2. Ring Outdoor Security Cam Microphone Replacement: adım 9, 3 resimden 3.
    • Pry the motherboard out with a plastic opening tool
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
    FixBot'a Sor
    Yorum Ekle
  10. Ring Outdoor Security Cam Microphone Replacement: adım 10, 1 resimden 1.
    • Remove the microphone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
WilliamB22
968 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
Where can i get the replacement?
Sam - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 45
Her zaman: 773
