Ana içeriğe geç
Ring Spotlight Cam Battery Motion Detector Replacement
Neye ihtiyacın var
  1. Ring Spotlight Cam Battery Motion Detector Replacement, Motion Detector: adım 1, 1 resimden 1.
    • Rotate the camera so the mounting bracket is facing you.
    • Turn the camera so the mounting bracket is at the bottom.
  2. Ring Spotlight Cam Battery Motion Detector Replacement: adım 2, 1 resimden 1.
    • Press the top button and slide your thumb upward to open the camera.
  3. Ring Spotlight Cam Battery Motion Detector Replacement: adım 3, 1 resimden 1.
    • Remove the batteries in the camera before proceeding.
    • Remove the two screws located in the middle of the cover with a Phillips #1 screwdriver.
  4. Ring Spotlight Cam Battery Motion Detector Replacement: adım 4, 1 resimden 1.
    • Remove the middle component.
  5. Ring Spotlight Cam Battery Motion Detector Replacement: adım 5, 1 resimden 1.
    • Remove the sticker on the cover.
    • Remove the 10 screws located around the edge of the cover.
  6. Ring Spotlight Cam Battery Motion Detector Replacement: adım 6, 1 resimden 1.
    • Carefully close the cover.
  7. Ring Spotlight Cam Battery Motion Detector Replacement: adım 7, 1 resimden 1.
    • Remove the cover and replace the LED light.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 2,173
