Ana içeriğe geç
Ring Spotlight Cam Battery The Mounting Bracket Replacement
Neye ihtiyacın var
  1. Ring Spotlight Cam Battery The Mounting Bracket  Replacement, The Mounting Bracket: adım 1, 1 resimden 1.
    • Place Mounting Bracket with lower elevation facing towards you.
  2. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the single bracket screw.
  3. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: adım 3, 1 resimden 1.
    • Hold two corners from the middle of bracket and stretch outward.
  4. Ring Spotlight Cam Battery The Mounting Bracket  Replacement: adım 4, 1 resimden 1.
    • Slide bracket upwards.
Sonuç
Bir Yorum
I have lost the single bracket screw. Where can I get a replacement?
Rick Burgess - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 2,815
