Ana içeriğe geç
Ring Stick Up Cam Battery Motherboard Replacement
Neye ihtiyacın var
  1. Ring Stick Up Cam Battery Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
  2. Ring Stick Up Cam Battery Motherboard Replacement: adım 2, 1 resimden 1.
    • Gently pull down to separate the stand from the camera body.
  3. Ring Stick Up Cam Battery Motherboard Replacement: adım 3, 2 resimden 1. Ring Stick Up Cam Battery Motherboard Replacement: adım 3, 2 resimden 2.
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
  4. Ring Stick Up Cam Battery Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
  5. Ring Stick Up Cam Battery Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
  6. Ring Stick Up Cam Battery Motherboard Replacement: adım 6, 1 resimden 1.
    • Rotate the device so the base is facing upward.
    • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
    • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
  7. Ring Stick Up Cam Battery Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the silver latch from the base.
    • Remove the front cover.
    • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
    • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
  8. Ring Stick Up Cam Battery Motherboard Replacement: adım 8, 1 resimden 1.
    • Pry the inside panel open using your hands or a spudger if necessary.
  9. Ring Stick Up Cam Battery Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
  10. Ring Stick Up Cam Battery Motherboard Replacement: adım 10, 2 resimden 1. Ring Stick Up Cam Battery Motherboard Replacement: adım 10, 2 resimden 2.
    • Lift the motherboard from the camera body with the halberd spudger.
  11. Ring Stick Up Cam Battery Motherboard Replacement: adım 11, 2 resimden 1. Ring Stick Up Cam Battery Motherboard Replacement: adım 11, 2 resimden 2.
    • Rotate the device to its side.
    • With your fingers, carefully remove the white part of the cord clip from the beige base.
    • Repeat this for the remaining three cords connecting the motherboard to the camera body.
  12. Ring Stick Up Cam Battery Motherboard Replacement: adım 12, 1 resimden 1.
    • Fold the motherboard downward from the camera body, revealing a white connecting strip.
    • Using the flat end of a spudger, flick the black hinge upward.
    • Pull the white strip out of the slot.
  13. Ring Stick Up Cam Battery Motherboard Replacement: adım 13, 2 resimden 1. Ring Stick Up Cam Battery Motherboard Replacement: adım 13, 2 resimden 2.
    • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
    • Gently remove the adhesive cover from the motherboard.
Sonuç
Vanessa Hasbrouck
339 İtibar
2 adet Kılavuz yazıldı
Ekip
Marist, Team 1-1, Chaterdon Spring 2023 Marist, Team 1-1, Chaterdon Spring 2023 üyesi
MARS-CHATERDON-S23S1G1
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Would like to see a chip identification teardown in the future please 😊
Bryan Watson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 188
