Giriş
If the audio of your Ring Stick Up Cam Battery (3rd Generation, model number 5UM7E5) is not present or distorted, use this guide to replace the speaker.
Prior to using this guide, ensure that there is nothing blocking the device or muffling the sound. Test the audio in the Ring app a few times to ensure that there is an audio issue. If there is nothing physically obstructing the audio, your speaker may need to be replaced. This guide will walk you through how to locate and replace the speaker inside your device. Before beginning, make sure to power off your device and disconnect it from the Ring app.
Neye ihtiyacın var
Turn the camera so the lens is facing away from you, and the back is facing towards you.
Place one hand securely on the base and the other on the stand.
Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
Orient your device so that the interior of the camera body is facing the ceiling.
Remove the two 4 mm screws connecting the metal protective piece to the camera body using a Phillips #00 screwdriver.
Use the hook end of the halberd spudger to carefully lift the microphone from the base.
Remove the two 4 mm screws from the upper black cover panel using a Phillips #00 screwdriver.
Remove the two 4 mm screws from the lower black cover panel using a Phillips #00 screwdriver.
