Ana içeriğe geç
Ring Stick Up Cam Camera Replacement
Neye ihtiyacın var
  1. Ring Stick Up Cam Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Camera Replacement: adım 2, 1 resimden 1.
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Camera Replacement: adım 3, 1 resimden 1.
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Camera Replacement: adım 4, 1 resimden 1.
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Camera Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Camera Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    Where do we buy a new battery from?
    lessonsinflight - Yanıt
    Battery specs would be great in this tear down so one can know what battery to get and have everything they need for the repair.
    Edward Clark - Yanıt
    I have these available if you would like one. The specs are 3.75 volt, 5000 mAh nominal. The ones I sell are OEM, used pulls from overstock or upgraded units.
    Solarescycle -
  7. Ring Stick Up Cam Camera Replacement, Camera: adım 7, 1 resimden 1.
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Camera Replacement: adım 8, 1 resimden 1.
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Camera Replacement: adım 9, 1 resimden 1.
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Camera Replacement: adım 10, 1 resimden 1.
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Camera Replacement: adım 11, 1 resimden 1.
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Camera Replacement: adım 12, 1 resimden 1.
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Camera Replacement: adım 13, 1 resimden 1.
    • Lift the camera board out of the housing using your hand.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ao Li
245 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S18-G3, Lore Winter 2019 UC Davis, Team S18-G3, Lore Winter 2019 üyesi
UCD-LORE-W19S18G3
3 Üyeler
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I purchase a new lens?
Javier Casas - Yanıt
Any ideas where to get a new lens?
Mete Doguoglu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 4,811
