Ana içeriğe geç
Ring Video Doorbell 3 Camera Replacement
Neye ihtiyacın var
  1. Ring Video Doorbell 3 Camera Replacement, Faceplate: adım 1, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement, Faceplate: adım 1, 2 resimden 2.
    • Look at the bottom of the device and locate the arrow.
    • Use your fingers to push the silver faceplate in the direction of the arrow.
  2. Ring Video Doorbell 3 Camera Replacement: adım 2, 1 resimden 1.
    • Push up to take the face plate off.
  3. Ring Video Doorbell 3 Camera Replacement, Battery: adım 3, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement, Battery: adım 3, 2 resimden 2.
    • Push in the silver tab and slide the battery out.
  4. Ring Video Doorbell 3 Camera Replacement, Motherboard: adım 4, 3 resimden 1. Ring Video Doorbell 3 Camera Replacement, Motherboard: adım 4, 3 resimden 2. Ring Video Doorbell 3 Camera Replacement, Motherboard: adım 4, 3 resimden 3.
    • Remove the 6 screws with a Torx T6 screwdriver.
    • Remove the 2 screws with a Torx T5 screwdriver.
  5. Ring Video Doorbell 3 Camera Replacement: adım 5, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement: adım 5, 2 resimden 2.
    • Put your thumb where the battery was and push outwards to remove the back case.
  6. Ring Video Doorbell 3 Camera Replacement: adım 6, 3 resimden 1. Ring Video Doorbell 3 Camera Replacement: adım 6, 3 resimden 2. Ring Video Doorbell 3 Camera Replacement: adım 6, 3 resimden 3.
    • Get a tweezer, and remove the black and grey antenna wires.
  7. Ring Video Doorbell 3 Camera Replacement: adım 7, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement: adım 7, 2 resimden 2.
    • Disconnect the camera sensor.
  8. Ring Video Doorbell 3 Camera Replacement: adım 8, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Be cautious to not rip the ribbon cable.
    • Lift the black tab above the ribbon to unlock it.
    • Use the tweezers to pull out the ribbon.
  9. Ring Video Doorbell 3 Camera Replacement: adım 9, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement: adım 9, 2 resimden 2.
    • Use a Torx T6 but to take out the four screws on the first motherboard.
  10. Ring Video Doorbell 3 Camera Replacement: adım 10, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement: adım 10, 2 resimden 2.
    • Use an opening tool to take out the motherboard.
    • Make sure to push in the 5 pins while taking out the motherboards to ensure that they do not break.
  11. Ring Video Doorbell 3 Camera Replacement: adım 11, 1 resimden 1.
    • The motherboard has been taken out, and now it is free to be replaced or worked on.
  12. Ring Video Doorbell 3 Camera Replacement: adım 12, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement: adım 12, 2 resimden 2.
    • Flip the two boards on the side.
    • Gently pull the motherboard and the camera board apart.
  13. Ring Video Doorbell 3 Camera Replacement: adım 13, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement: adım 13, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the two screws.
  14. Ring Video Doorbell 3 Camera Replacement: adım 14, 2 resimden 1. Ring Video Doorbell 3 Camera Replacement: adım 14, 2 resimden 2.
    • Carefully remove the camera lens from the board.
    • Replace Motherboard(s) if needed.
    • Replace Camera if needed.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 181
