Ana içeriğe geç
Ring Video Doorbell Battery Replacement
Neye ihtiyacın var
  1. Ring Video Doorbell Battery Replacement, Battery: adım 1, 3 resimden 1. Ring Video Doorbell Battery Replacement, Battery: adım 1, 3 resimden 2. Ring Video Doorbell Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Battery Replacement: adım 2, 3 resimden 1. Ring Video Doorbell Battery Replacement: adım 2, 3 resimden 2. Ring Video Doorbell Battery Replacement: adım 2, 3 resimden 3.
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Abdulrahman
709 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G5, Cheng Spring 2018 USF Tampa, Team S11-G5, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G5
3 Üyeler
10 adet Kılavuz yazıldı
7 Yorum
Where do I get a replacement battery?
William Price - Yanıt
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - Yanıt
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - Yanıt
can it be sent to the manufacturers for a replacement
d.rayyan - Yanıt
similar to David, I pulled off the battery connector and reattached it, then sealed with some rubber cement. Unit immediately went back online.
Daniel Wise - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 67
Son 30 gün: 390
Her zaman: 12,903
