Giriş
In this guide, you will be shown how to take apart the housing unit in order to replace the battery of the Ring Video Doorbell, step-by-step. You will need only a Plastic Tool Opener for this.
Neye ihtiyacın var
Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
Pry open the aluminium plate using the Plastic Opening Tool(s).
Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
Where do I get a replacement battery?
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
similar to David, I pulled off the battery connector and reattached it, then sealed with some rubber cement. Unit immediately went back online.
Thanks for the guide. NOTE TO OTHERS: the battery connector pins are very fine and fragile, and truly a challenge to reconnect. be sure to try to pry up the connector straight up, else the pins will bend over, then good luck reconnecting!
Front door bell camera no longer works. Tried everything, no results. Is there anything special I need to do to trash the darn thing and install a regular doorbell?
