Ana içeriğe geç
Ring Video Doorbell Motherboard Replacement
Neye ihtiyacın var
  1. Ring Video Doorbell Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Ring Video Doorbell Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Ring Video Doorbell Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Motherboard Replacement: adım 2, 3 resimden 1. Ring Video Doorbell Motherboard Replacement: adım 2, 3 resimden 2. Ring Video Doorbell Motherboard Replacement: adım 2, 3 resimden 3.
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell Motherboard Replacement: adım 3, 3 resimden 1. Ring Video Doorbell Motherboard Replacement: adım 3, 3 resimden 2. Ring Video Doorbell Motherboard Replacement: adım 3, 3 resimden 3.
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell Motherboard Replacement: adım 4, 2 resimden 1. Ring Video Doorbell Motherboard Replacement: adım 4, 2 resimden 2.
    • Detach the upper part of the motherboard from the bottom, using your hands.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Abdulrahman
709 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G5, Cheng Spring 2018 USF Tampa, Team S11-G5, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G5
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Where can you buy a replacement motherboard?
Barry Specter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 52
Her zaman: 4,535
