Ana içeriğe geç
Ring Video Doorbell Pro Capacitor Replacement
Neye ihtiyacın var
  1. Ring Video Doorbell Pro Capacitor Replacement, Housing: adım 1, 1 resimden 1.
    • Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
  2. Ring Video Doorbell Pro Capacitor Replacement: adım 2, 3 resimden 1. Ring Video Doorbell Pro Capacitor Replacement: adım 2, 3 resimden 2. Ring Video Doorbell Pro Capacitor Replacement: adım 2, 3 resimden 3.
    • Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device.
  3. Ring Video Doorbell Pro Capacitor Replacement: adım 3, 1 resimden 1.
    • Using a PH-000 screwdriver, unscrew and set aside all four of these 5.25 mm screws.
  4. Ring Video Doorbell Pro Capacitor Replacement: adım 4, 2 resimden 1. Ring Video Doorbell Pro Capacitor Replacement: adım 4, 2 resimden 2.
    • Using a plastic pry tool, go along the edge of the device prying the device apart. While doing this, focus on the four clips, two of which are on either side of the device.
  5. Ring Video Doorbell Pro Capacitor Replacement: adım 5, 1 resimden 1.
    • Remove the front of the device from the back plate.
  6. Ring Video Doorbell Pro Capacitor Replacement, Speaker: adım 6, 1 resimden 1.
    • With the Video Doorbell Pro opened up the speaker is exposed.
  7. Ring Video Doorbell Pro Capacitor Replacement: adım 7, 1 resimden 1.
    • Remove this 5.25 mm screw.
  8. Ring Video Doorbell Pro Capacitor Replacement: adım 8, 1 resimden 1.
    • Remove this wire connection by gently prying it off with a plastic pry tool.
  9. Ring Video Doorbell Pro Capacitor Replacement: adım 9, 1 resimden 1.
    • Remove the speaker from the device.
  10. Ring Video Doorbell Pro Capacitor Replacement, Motherboard: adım 10, 1 resimden 1.
    • The next step is to remove the last four connections holding the motherboard in place.
  11. Ring Video Doorbell Pro Capacitor Replacement: adım 11, 1 resimden 1.
    • Using the plastic pry tool, carefully remove this wire connection.
  12. Ring Video Doorbell Pro Capacitor Replacement: adım 12, 1 resimden 1.
    • Using the plastic pry tool, gently ease this ribbon cable from its port.
  13. Ring Video Doorbell Pro Capacitor Replacement: adım 13, 1 resimden 1.
    • Remove the last two wire connections shown here using the same methods utilized in the previous steps.
  14. Ring Video Doorbell Pro Capacitor Replacement: adım 14, 2 resimden 1. Ring Video Doorbell Pro Capacitor Replacement: adım 14, 2 resimden 2.
    • Using the Phillips 000 screwdriver, remove these three 4.25mm screws.
  15. Ring Video Doorbell Pro Capacitor Replacement: adım 15, 1 resimden 1.
    • Take the motherboard out of the housing. Lift slowly while doing this to make sure the wires and the delicate ribbon cable are not damaged.
  16. Ring Video Doorbell Pro Capacitor Replacement, Capacitor: adım 16, 1 resimden 1.
    • Remove the capacitor.
Sonuç
To reassemble your device, insert the new capacitor and follow these instructions in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
Jake Dixon
850 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S7-G4, Baechle Fall 2017 IUPUI, Team S7-G4, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S7G4
3 Üyeler
5 adet Kılavuz yazıldı
8 Yorum
where can I buy the replacement capacitor please or is it a case of buying a standard and making up the lead?
Umesh Radia - Yanıt
is that a battery right next to it? why didn’t you pull/mention that also?
Adrian Osio - Yanıt
I have the ring pro. What is the battery specification and what is the capacitor specification? If I going to all that work I need the replacement parts on hand.
Kent - Yanıt
The capacitor is a 470 uF/ 50 VDC electrolytic capacitor.
Battery is 350 mAh 3.7 volt Li 602030.
602030 battery listing: https://www.aliexpress.com/item/33029703...
tmiller -
What symptoms do you have that is causing you to replace the capacitor?
What symptoms do you have that is causing you to replace the battery ?
My inside chimes only chimes when it is cool outside or just randomly. It is hard to track down. The transformer seems strong.
Kent - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 11,302
