Giriş
This guide will explain step-by-step how to replace the speaker in a Ring Video Doorbell Pro.
Neye ihtiyacın var
Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
To reassemble your device, insert the new speaker and follow these instructions in reverse order.
6 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Hi Jake. This looks brilliant - I would love to contact you directly as I have a further question about this. My member name is robinfeild, and my email is email is robinfeild@gmail.com.
Hope to hear from you!
Thanks
Robin
Anyone happen to know where you can purchase the replacement speaker from?
Where did you get a replacement speaker from?
I dismantled the speaker in mine having verified it was faulty by testing it with one from a standard Ring Doorbell, (It has the same connector but the housing is a different shape. Having cracked open the plastic housing of the speaker it has one of these inside (1w 8 Ohm Rectangular speaker 15*11*3.5mm) such as https://www.ebay.co.uk/itm/224485373996 a couple of drops of superglue and two dabs of solder, works like new.
