Ana içeriğe geç
Rival 16131 Toaster bread grabber spring replacement
Neye ihtiyacın var
  1. Rival 16131 Toaster bread grabber spring replacement, Shell: adım 1, 2 resimden 1. Rival 16131 Toaster bread grabber spring replacement, Shell: adım 1, 2 resimden 2.
    • Make sure the toaster is unplugged before dissembling.
    • Turn the toaster over and remove the rubber bumper feet.
    FixBot'a Sor
    Yorum Ekle
  2. Rival 16131 Toaster bread grabber spring replacement: adım 2, 2 resimden 1. Rival 16131 Toaster bread grabber spring replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove four 12 mm screws at the base of the toaster shell.
    FixBot'a Sor
    Yorum Ekle
  3. Rival 16131 Toaster bread grabber spring replacement: adım 3, 3 resimden 1. Rival 16131 Toaster bread grabber spring replacement: adım 3, 3 resimden 2. Rival 16131 Toaster bread grabber spring replacement: adım 3, 3 resimden 3.
    • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
    • When reassembling the toaster, make sure that the back of the dial lines up with the slot, both in position and orientation (the dial and slot are not perfect circles - they have a notch).
    • The only object holding the shell onto the toaster now is the grey part of the lever.
    FixBot'a Sor
    Yorum Ekle
  4. Rival 16131 Toaster bread grabber spring replacement: adım 4, 1 resimden 1.
    • Reach into the shell and grab the back white part of the lever.
    • Hold the grey lever with both your index finger and middle finger. Next, pull it.
    • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
    • Remove the shell.
    FixBot'a Sor
    Yorum Ekle
  5. Rival 16131 Toaster bread grabber spring replacement, Bread Grabber Springs: adım 5, 1 resimden 1.
    • Locate the black, diamond shaped spring behind the white lever bracket.
    FixBot'a Sor
    Yorum Ekle
  6. Rival 16131 Toaster bread grabber spring replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • To remove the spring, use the tweezers to push the bottom edge of the spring out and around the metal bracket that keeps the springs in place.
    • Repeat this for the other side.
    FixBot'a Sor
    Yorum Ekle
  7. Rival 16131 Toaster bread grabber spring replacement: adım 7, 1 resimden 1.
    • Pulling the bottom of the spring out, lift the left circle up over the metal bracket that extends out from the bread grabbers.
    • Bring the right circle out, down, and around the bracket the extends out from the shelf that the toast would sits on.
    • Remove the right circle.
    FixBot'a Sor
    Yorum Ekle
  8. Rival 16131 Toaster bread grabber spring replacement: adım 8, 1 resimden 1.
    • Make sure that all the angles are similar to the other metal spring.
    • If not, then bend the broken spring to the angles of the correct spring.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Grant Haug
148 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-8, Propen Fall 2012 Cal Poly, Team 2-8, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G8
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 49
Her zaman: 4,534
