Ana içeriğe geç
Rival CM4015 Heating Element Replacement
Neye ihtiyacın var
    1. Rival CM4015 Heating Element Replacement, Base Plate: adım 1, 2 resimden 1. Rival CM4015 Heating Element Replacement, Base Plate: adım 1, 2 resimden 2.
      • Remove the three 16 mm tri-point screws from the base plate.
      FixBot'a Sor
      Yorum Ekle
    2. Rival CM4015 Heating Element Replacement: adım 2, 2 resimden 1. Rival CM4015 Heating Element Replacement: adım 2, 2 resimden 2.
      • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
      FixBot'a Sor
      Yorum Ekle
    1. Rival CM4015 Heating Element Replacement, Power Button: adım 3, 1 resimden 1.
      • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
      FixBot'a Sor
      Yorum Ekle
    2. Rival CM4015 Heating Element Replacement: adım 4, 2 resimden 1. Rival CM4015 Heating Element Replacement: adım 4, 2 resimden 2.
      • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
      • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
      FixBot'a Sor
      Yorum Ekle
    3. Rival CM4015 Heating Element Replacement: adım 5, 2 resimden 1. Rival CM4015 Heating Element Replacement: adım 5, 2 resimden 2.
      • Clean both the button and its slot before replacing the power button.
      FixBot'a Sor
      Yorum Ekle
    1. Rival CM4015 Heating Element Replacement, Heating Element: adım 6, 1 resimden 1.
      • Remove the two 8 mm Phillips screws from the plastic body.
      FixBot'a Sor
      Yorum Ekle
    2. Rival CM4015 Heating Element Replacement: adım 7, 2 resimden 1. Rival CM4015 Heating Element Replacement: adım 7, 2 resimden 2.
      • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
      • Pull back the metal backing from the plastic body.
      FixBot'a Sor
      Yorum Ekle
    3. Rival CM4015 Heating Element Replacement: adım 8, 3 resimden 1. Rival CM4015 Heating Element Replacement: adım 8, 3 resimden 2. Rival CM4015 Heating Element Replacement: adım 8, 3 resimden 3.
      • Remove the four 8 mm Phillips screws from the inner plastic body.
      • You will need a long, thin Phillips screw driver to get this deep into the device.
      FixBot'a Sor
      Yorum Ekle
    4. Rival CM4015 Heating Element Replacement: adım 9, 2 resimden 1. Rival CM4015 Heating Element Replacement: adım 9, 2 resimden 2.
      • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
      • Take your time to make sure the thin cables within the device don't tear.
      FixBot'a Sor
      Yorum Ekle
    5. Rival CM4015 Heating Element Replacement: adım 10, 1 resimden 1.
      • Remove the two 8 mm Phillips screws from the metal backing.
      FixBot'a Sor
      Yorum Ekle
    6. Rival CM4015 Heating Element Replacement: adım 11, 1 resimden 1.
      • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
      • You may also use pliers for this step if the springs are too strong.
      FixBot'a Sor
      Yorum Ekle
    7. Rival CM4015 Heating Element Replacement: adım 12, 1 resimden 1.
      • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Murdock
279 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-6, Livingston Fall 2016 Cal Poly, Team 10-6, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G6
5 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 680
