Ana içeriğe geç
Rival CM4015 Power Cable Replacement
Neye ihtiyacın var
    1. Rival CM4015 Power Cable Replacement, Base Plate: adım 1, 2 resimden 1. Rival CM4015 Power Cable Replacement, Base Plate: adım 1, 2 resimden 2.
      • Remove the three 16 mm tri-point screws from the base plate.
      FixBot'a Sor
      Yorum Ekle
    2. Rival CM4015 Power Cable Replacement: adım 2, 2 resimden 1. Rival CM4015 Power Cable Replacement: adım 2, 2 resimden 2.
      • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
      FixBot'a Sor
      Yorum Ekle
    1. Rival CM4015 Power Cable Replacement, Power Cable: adım 3, 1 resimden 1.
      • Remove the two 8mm Phillips screws from the plastic body.
      FixBot'a Sor
      Yorum Ekle
    2. Rival CM4015 Power Cable Replacement: adım 4, 1 resimden 1.
      • Pull the cord and cut the black and red wires across the black heat shrink.
      • Be careful when soldering the new power cable.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Luis Villalpando
113 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-6, Livingston Fall 2016 Cal Poly, Team 10-6, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G6
5 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 405
