Ana içeriğe geç
Rival Crock Pot 3120 Disassembly
Neye ihtiyacın var
Öne Çıkan Belge
  1. Rival Crock Pot 3120 Disassembly, Rival Crock Pot 3120 Disassembly: adım 1, 1 resimden 1.
    • Remove the lid from the crockpot and turn the device over, so that the bottom faces up.
  2. Rival Crock Pot 3120 Disassembly: adım 2, 2 resimden 1. Rival Crock Pot 3120 Disassembly: adım 2, 2 resimden 2.
    • Use your fingers to remove the rubber end cap from the bolt on the bottom of the device.
  3. Rival Crock Pot 3120 Disassembly: adım 3, 2 resimden 1. Rival Crock Pot 3120 Disassembly: adım 3, 2 resimden 2.
    • Using a 10mm wrench, remove the metal nut on the bottom of the device.
    • If the bolt connected to the nut appeared to fall into the device this is not an issue. It is connected to a metal bar within the device, so it cannot be lost.
  4. Rival Crock Pot 3120 Disassembly: adım 4, 2 resimden 1. Rival Crock Pot 3120 Disassembly: adım 4, 2 resimden 2.
    • Using your hands, pull the plastic dial off the side of the device.
  5. Rival Crock Pot 3120 Disassembly: adım 5, 3 resimden 1. Rival Crock Pot 3120 Disassembly: adım 5, 3 resimden 2. Rival Crock Pot 3120 Disassembly: adım 5, 3 resimden 3.
    • Remove the nut behind the dial using a 16mm wrench.
    • Once the nut has been loosened you can finish unscrewing it with your hand.
  6. Rival Crock Pot 3120 Disassembly: adım 6, 3 resimden 1. Rival Crock Pot 3120 Disassembly: adım 6, 3 resimden 2. Rival Crock Pot 3120 Disassembly: adım 6, 3 resimden 3.
    • Remove the bottom panel using your hands.
  7. Rival Crock Pot 3120 Disassembly: adım 7, 3 resimden 1. Rival Crock Pot 3120 Disassembly: adım 7, 3 resimden 2. Rival Crock Pot 3120 Disassembly: adım 7, 3 resimden 3.
    • Slide the power cord out of its slot in the metal casing.
  8. Rival Crock Pot 3120 Disassembly: adım 8, 2 resimden 1. Rival Crock Pot 3120 Disassembly: adım 8, 2 resimden 2.
    • Pull the rotary switch out from inside the metal casing.
  9. Rival Crock Pot 3120 Disassembly: adım 9, 3 resimden 1. Rival Crock Pot 3120 Disassembly: adım 9, 3 resimden 2. Rival Crock Pot 3120 Disassembly: adım 9, 3 resimden 3.
    • Slide the metal casing up and away from the internal components of the device.
  10. Rival Crock Pot 3120 Disassembly: adım 10, 3 resimden 1. Rival Crock Pot 3120 Disassembly: adım 10, 3 resimden 2. Rival Crock Pot 3120 Disassembly: adım 10, 3 resimden 3.
    • You have now successfully disassembled your device. From here you can troubleshoot or replace any specific parts.
Sonuç
Ekli Belgeler
4 Yorum
Reassembly is difficult, the bolt on the bottom is too short!
Johnb - Yanıt
Bolt is way too short to reassemble this thing and I'm not strong enough to bend the wire bail no matter how I try to do it. Never should have taken the thing apart.
Bob Hodge - Yanıt
It has been quite a long time since I went through this process but I seem to remember wrapping the threaded part of the bot in dental floss to use as a guide and threaded it through the hole with the crockpot propped up, upright so gravity would aid in assembly (some tire chocks on their sides would work, I think). It took some patience or perhaps stubbornness? But that's how I got it reassembled. I had a really hard time getting the bolt centered and the wire bail part vertical, which made the bolt seem impossibly short, before I tried this approach.
D. Marie Olsen Zito -
The bolt is definitely too short. I was taking it apart to clean it up- had I known, I wouldn't have bothered. I did bend the wire and tied some thread to the bolt- I was determined to not let it get the best of me.
Those heating wires that wrap around the pot are so thin, I was worried about breaking one. When I got it out back together I put some water in it and turn it on low- it was still working.
John Kershisnik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 50
Her zaman: 1,261
