Ana içeriğe geç
Rival Mini Chopper MC-67BL Turning Gears Replacement
Neye ihtiyacın var
  1. Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: adım 1, 2 resimden 1. Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: adım 1, 2 resimden 2.
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 2, 1 resimden 1.
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 3, 1 resimden 1.
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 4, 1 resimden 1.
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 5, 2 resimden 1. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 5, 2 resimden 2.
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 6, 1 resimden 1.
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 7, 1 resimden 1.
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 8, 3 resimden 1. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 8, 3 resimden 2. Rival Mini Chopper MC-67BL Turning Gears Replacement: adım 8, 3 resimden 3.
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Roxanne
522 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-29, Amido Fall 2013 Cal Poly, Team 4-29, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G29
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 783
