Ana içeriğe geç
Road Bike Presta Valve Inner Tube Replacement
Neye ihtiyacın var
  1. Road Bike Presta Valve Inner Tube Replacement, Presta Valve Inner Tube: adım 1, 2 resimden 1. Road Bike Presta Valve Inner Tube Replacement, Presta Valve Inner Tube: adım 1, 2 resimden 2.
    • Flip the bike upside down.
  2. Road Bike Presta Valve Inner Tube Replacement: adım 2, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 2, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 2, 3 resimden 3.
    • Find the Presta valve of the tire, then remove the cap by turning counter-clockwise.
  3. Road Bike Presta Valve Inner Tube Replacement: adım 3, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 3, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 3, 3 resimden 3.
    • Twist the tip of the Presta valve counter-clockwise.
  4. Road Bike Presta Valve Inner Tube Replacement: adım 4, 2 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 4, 2 resimden 2.
    • Press firmly on the valve to release the air in the tube.
    • Hold firmly until there is no more air left.
  5. Road Bike Presta Valve Inner Tube Replacement: adım 5, 2 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 5, 2 resimden 2.
    • Lift the lever on the brake assembly of the wheel to release the brakes.
  6. Road Bike Presta Valve Inner Tube Replacement: adım 6, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 6, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 6, 3 resimden 3.
    • Unscrew the cap of the front wheel spoke by turning it counter-clockwise.
  7. Road Bike Presta Valve Inner Tube Replacement: adım 7, 2 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 7, 2 resimden 2.
    • Firmly grab the lever on the other side of the spoke and lift it up.
  8. Road Bike Presta Valve Inner Tube Replacement: adım 8, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 8, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 8, 3 resimden 3.
    • Grab the top of the wheel, and gently lift it off the frame of the bike.
  9. Road Bike Presta Valve Inner Tube Replacement: adım 9, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 9, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 9, 3 resimden 3.
    • Find the Presta valve, and unscrew the nut at the bottom of the Presta valve.
  10. Road Bike Presta Valve Inner Tube Replacement: adım 10, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 10, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 10, 3 resimden 3.
    • Insert the two tire levers on the opposite side of the Presta Valve, placing each one about 10 inches apart.
    • The side the levers are on doesn't matter, but ensure both levers are on the same side of the wheel.
  11. Road Bike Presta Valve Inner Tube Replacement: adım 11, 1 resimden 1.
    • Push both tire levers down until the tire lifts off the rim.
  12. Road Bike Presta Valve Inner Tube Replacement: adım 12, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 12, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 12, 3 resimden 3.
    • Firmly push the side of the tire that is off the rim.
    • Repeat the action of pushing around the entire wheel until one side of the wheel is off the rim.
  13. Road Bike Presta Valve Inner Tube Replacement: adım 13, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 13, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 13, 3 resimden 3.
    • Grab the inner tube from the inside of the tire, and pull the rest of the tube out.
    • Remove the inner tube from the wheel by pulling the part of the tube that is attached to the Presta Valve until the valve slides out from the wheel.
  14. Road Bike Presta Valve Inner Tube Replacement: adım 14, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 14, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 14, 3 resimden 3.
    • With the new tube, insert the Presta valve into the hole of the rim.
    • If there is a nut on the Presta Valve, make sure it is off before you insert the tube into the rim.
  15. Road Bike Presta Valve Inner Tube Replacement: adım 15, 2 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 15, 2 resimden 2.
    • Starting from where the valve is, push the side of the tire that was off the rim back onto the rim, making sure the tube is inside the tire.
    • Repeat this going down the right side of the tire, stopping at halfway point of the rim.
  16. Road Bike Presta Valve Inner Tube Replacement: adım 16, 1 resimden 1.
    • Push in the tire from the left side of the rim, and repeat this going down the rim until it gets too difficult to push anymore.
  17. Road Bike Presta Valve Inner Tube Replacement: adım 17, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 17, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 17, 3 resimden 3.
    • Insert the tire lever before the last bit of the tire that is not in the rim.
    • Grab the rim with one hand, and use your other hand to grab the tire lever and push down until the tire is back on the rim.
  18. Road Bike Presta Valve Inner Tube Replacement: adım 18, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 18, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 18, 3 resimden 3.
    • Twist the nut for the Presta valve clockwise until it secures the Presta valve.
  19. Road Bike Presta Valve Inner Tube Replacement: adım 19, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 19, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 19, 3 resimden 3.
    • Grab the wheel and put it back on the fork of the bike.
  20. Road Bike Presta Valve Inner Tube Replacement: adım 20, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 20, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 20, 3 resimden 3.
    • Screw the Presta valve cap back on the Presta valve.
  21. Road Bike Presta Valve Inner Tube Replacement: adım 21, 3 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 21, 3 resimden 2. Road Bike Presta Valve Inner Tube Replacement: adım 21, 3 resimden 3.
    • Loosely tighten the cap of the spoke by turning the cap clockwise.
    • Stop when you start to feel the cap is pressing against the fork.
  22. Road Bike Presta Valve Inner Tube Replacement: adım 22, 2 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 22, 2 resimden 2.
    • Push the lever on the spoke down.
  23. Road Bike Presta Valve Inner Tube Replacement: adım 23, 2 resimden 1. Road Bike Presta Valve Inner Tube Replacement: adım 23, 2 resimden 2.
    • Push down the brake lever.
Sonuç
kb03
337 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-6, Morris Spring 2024 UC Davis, Team 1-6, Morris Spring 2024 üyesi
UCD-MORRIS-S24S1G6
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 154
