Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Roborock Auto-empty Dock cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Roborock Auto-empty Dock (Onyx): Teardown, Roborock Auto-empty Dock (Onyx): Teardown: adım 1, 1 resimden 1.
    • Let's begin by removing its ramp. Flip it on it's head.
    • Use a PH2 screwdriver to unscrew the screws, then take the ramp off.
  2. Roborock Auto-empty Dock (Onyx): Teardown: adım 2, 2 resimden 1. Roborock Auto-empty Dock (Onyx): Teardown: adım 2, 2 resimden 2.
    • Remove the marked screws.
    • Circled in red are PH2.
    • Circled in orange are PH1.
    • Then pull the bottom cover off.
  3. Roborock Auto-empty Dock (Onyx): Teardown: adım 3, 3 resimden 1. Roborock Auto-empty Dock (Onyx): Teardown: adım 3, 3 resimden 2. Roborock Auto-empty Dock (Onyx): Teardown: adım 3, 3 resimden 3.
    • All are PH1.
    • Bend the contacts back (img3) to prevent them from shorting the PSU once you pull the assembly out.
  4. Roborock Auto-empty Dock (Onyx): Teardown: adım 4, 2 resimden 1. Roborock Auto-empty Dock (Onyx): Teardown: adım 4, 2 resimden 2.
    • Remove the cables.
    • Use these images as reference when reassembling.
  5. Roborock Auto-empty Dock (Onyx): Teardown: adım 5, 3 resimden 1. Roborock Auto-empty Dock (Onyx): Teardown: adım 5, 3 resimden 2. Roborock Auto-empty Dock (Onyx): Teardown: adım 5, 3 resimden 3.
    • Take out the PCBA+PSU assembly.
    • When taking out the assembly, make sure to disconnect the other connectors. I forgot to take pictures of these, so just take it out carefully.
    • Remove the connecting cable between the PSU and the main PBCA.
    • Unscrew the PSU.
    • Remove the PSU.
  6. Roborock Auto-empty Dock (Onyx): Teardown, Cat.: adım 6, 1 resimden 1.
    • I caught her.
DegenFixer
5.111 İtibar
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 98
Her zaman: 1,007
